Group: DynoMotion Message: 5701 From: Bengt Sjoelund Date: 9/23/2012
Subject: Rigid tapping - problems
As I have a job at hand with a lot of holes to be drilled and tapped I just tested the code to what works? I get to line 150 when I get a popup saying Unexpected motionbuffer starved.
What can be done to get things working?
Cheers
Bengt
N0000 (Filename: faceplate1.tap)
N0010 (Post processor: Mach3.scpost)
N0020 (Date:2012-09-22 Time:19:07:03)
N0030 G21 (Units: Metric)
N0040 G40 G90 G91.1
N0050 F1
N0060 (Part: faceplate1)
N0070 (Operation: Tap, H�L, T8: Rigid tap, 12 mm x 1 mm, 20 mm Deep)
N0080 S200 (Rigid tap, 12 mm x 1 mm)
N0090 T8 M06 G43 H8
N0100 G00 Z4.0000
N0110 S200 M03
N0120 M49
N0130 G95
N0140 M03
N0150 X110.0000 Y75.0000
N0160 Z1.0000
N0170 G01 Z-16.000 F1
N0180 M05
N0190 M04
N0200 Z1.000
N0210 M05
Group: DynoMotion Message: 5702 From: tmday7 Date: 9/23/2012
Subject: Re: Rigid tapping - problems
Hello Bengt,
Not sure, but did you try to increase the "Windows Buffer ahead time" in the plugin for Mach3? Increasing this will also delay the reaction time when adjusting feedrate override.
Troy
--- In DynoMotion@yahoogroups.com, "Bengt Sjoelund" <cnc@...> wrote:
> Hi Tom,
> Cheers
> Bengt
> N0040 G40 G90 G91.1
> N0050 F1
> N0090 T8 M06 G43 H8
> N0100 G00 Z4.0000
> N0110 S200 M03
> N0120 M49
> N0130 G95
> N0140 M03
> N0160 Z1.0000
> N0180 M05
> N0190 M04
> N0200 Z1.000
> N0210 M05
Group: DynoMotion Message: 5703 From: bsjoelund Date: 9/23/2012
Sorry guys,
I am really embarrassed. I was testing my code too close to X+ end switch that is why I got the error message. Code is running well, just uploading video to Youtube so I will post a link when ready.
Only thing that I can see is that the Z axis movement stops before the spindle and Z starts moving before spindle starts rotating. Lucky I have a floating tapping head with at least 5mm travel.
Video link soon
Cheers
Bengt
--- In DynoMotion@yahoogroups.com, "today 7" <brotroy7@...> wrote:
> Hello Bengt,
> Not sure, but did you try to increase the "Windows Buffer ahead time" in the plugin for Mach3? Increasing this will also delay the reaction time when adjusting feed rate override.
> Troy
> --- In DynoMotion@yahoogroups.com, "Bengt Sjölund" <cnc@> wrote:
> > Hi Tom,
> > As I have a job at hand with a lot of holes to be drilled and tapped I just tested the code to what works? I get to line 150 when I get a pop up saying Unexpected motionbuffer starved.
> > Cheers
> > Bengt
> > N0000 (Filename: faceplate 1.tap)
> > N0010 (Post processor: Mach3.post)
> > N0040 G40 G90 G91.1
> > N0050 F1
> > N0060 (Part: faceplate 1)
> > N0090 T8 M06 G43 H8
> > N0100 G00 Z4.0000
> > N0110 S200 M03
> > N0120 M49
> > N0130 G95
> > N0140 M03
> > N0160 Z1.0000
> > N0180 M05
> > N0190 M04
> > N0200 Z1.000
> > N0210 M05
Group: DynoMotion Message: 5704 From: Tom Kerekes Date: 9/23/2012
Hi Bengt,
Mach3 is not really designed to do true rigid tapping.  To do real rigid tapping you need to use a special method involving an M code and C program described here:
Sent: Sunday, September 23, 2012 7:50 AM
Subject: [DynoMotion] Re: Rigid tapping - problems
Sorry guys,
Video link soon
Cheers
Bengt
--- In mailto:DynoMotion%40yahoogroups.com, "today 7" <brotroy7@...> wrote:
> Hello Bengt,
> Troy
> --- In mailto:DynoMotion%40yahoogroups.com, "Bengt Sjölund" <cnc@> wrote:
> > Hi Tom,
> > Cheers
> > Bengt
> > N0040 G40 G90 G91.1
> > N0050 F1
> > N0070 (Operation: Tap, H&#65533;L, T8: Rigid tap, 12 mm x 1 mm, 20 mm Deep)
> > N0090 T8 M06 G43 H8
> > N0100 G00 Z4.0000
> > N0110 S200 M03
> > N0120 M49
> > N0130 G95
> > N0140 M03
> > N0160 Z1.0000
> > N0180 M05
> > N0190 M04
> > N0200 Z1.000
> > N0210 M05
Group: DynoMotion Message: 5705 From: Bengt Sjoelund Date: 9/23/2012
http://youtu.be/ENppnF6aS9I
As long as I can get by with the floating tapping head I am a happy camper. Will do some more test after dinner, one hole to be threaded.
Cheers
Bengt
> Hi Bengt,
> http://www.dynomotion.com/Help/Mach3Plugin/Mach3RigidTapping.htm
> From: bsjoelund <cnc@...>
> Sorry guys,
> Video link soon
> Cheers
> Bengt
> --- In mailto:DynoMotion%40yahoogroups.com, "today 7" <brotroy7@> wrote:
> > Hello Bengt,
> > Troy
> > > Hi Tom,
> > > Cheers
> > > Bengt
> > > N0040 G40 G90 G91.1
> > > N0050 F1
> > > N0090 T8 M06 G43 H8
> > > N0100 G00 Z4.0000
> > > N0110 S200 M03
> > > N0120 M49
> > > N0130 G95
> > > N0140 M03
> > > N0160 Z1.0000
> > > N0180 M05
> > > N0190 M04
> > > N0200 Z1.000
> > > N0210 M05
Group: DynoMotion Message: 5706 From: Bengt Sjoelund Date: 9/23/2012
Now I have tested to tap M6 threads in aluminium 20mm deep.
All well so I am a happy camper.
http://youtu.be/7gG0TsThMHI
Here the floating head in action, here you can see when Z axis stops and spindle still rotating how the floating toolholder expands.
Now I can star to drill/countersink/tap a lot of holes to two types of toolingplates for my lathe. Will show pictures/video later on.
Cheers
Bengt
> Hi Tom,
> Cheers
> Bengt
> > Hi Bengt,
> > From: bsjoelund <cnc@>
> > Sorry guys,
> > Video link soon
> > Cheers
> > Bengt
> > > Hello Bengt,
> > > Troy
> > > > Hi Tom,
> > > > Cheers
> > > > Bengt
> > > > N0040 G40 G90 G91.1
> > > > N0050 F1
> > > > N0090 T8 M06 G43 H8
> > > > N0100 G00 Z4.0000
> > > > N0110 S200 M03
> > > > N0120 M49
> > > > N0130 G95
> > > > N0140 M03
> > > > N0160 Z1.0000
> > > > N0180 M05
> > > > N0190 M04
> > > > N0200 Z1.000
> > > > N0210 M05
